Hi all
I’ll explain in next post but i put log for errors here:
Using core ‘esp8266’ from platform in folder: C:\Users\Jean-Charles\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4
Using board ‘d1_mini’ from platform in folder: C:\Users\Jean-Charles\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4
Detecting libraries used…
“C:\Users\Jean-Charles\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\2.5.0-4-b40a506/bin/xtensa-lx106-elf-g++” -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ “-IC:\Users\Jean-Charles\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4/tools/sdk/include” “-IC:\Users\Jean-Charles\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4/tools/sdk/lwip2/include” “-IC:\Users\Jean-Charles\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4/tools/sdk/libc/xtensa-lx106-elf/include” “-IC:\Users\JEAN-C~1\AppData\Local\Temp\arduino_build_459886/core” -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10812 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 “-DARDUINO_BOARD=“ESP8266_WEMOS_D1MINI”” -DFLASHMODE_DIO -DESP8266 “-IC:\Users\Jean-Charles\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4\cores\esp8266” “-IC:\Users\Jean-Charles\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4\variants\d1_mini” “C:\Users\JEAN-C~1\AppData\Local\Temp\arduino_build_459886\sketch\ESPboyInit.cpp.cpp” -o nul
Alternatives for Adafruit_MCP23017.h: [Adafruit_MCP23017_Arduino_Library@1.0.6]
ResolveLibrary(Adafruit_MCP23017.h)
-> candidates: [Adafruit_MCP23017_Arduino_Library@1.0.6]
“C:\Users\Jean-Charles\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\2.5.0-4-b40a506/bin/xtensa-lx106-elf-g++” -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ “-IC:\Users\Jean-Charles\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4/tools/sdk/include” “-IC:\Users\Jean-Charles\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4/tools/sdk/lwip2/include” “-IC:\Users\Jean-Charles\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4/tools/sdk/libc/xtensa-lx106-elf/include” “-IC:\Users\JEAN-C~1\AppData\Local\Temp\arduino_build_459886/core” -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10812 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 “-DARDUINO_BOARD=“ESP8266_WEMOS_D1MINI”” -DFLASHMODE_DIO -DESP8266 “-IC:\Users\Jean-Charles\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4\cores\esp8266” “-IC:\Users\Jean-Charles\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4\variants\d1_mini” “-IC:\Program Files (x86)\Arduino\libraries\Adafruit_MCP23017_Arduino_Library” “C:\Users\JEAN-C~1\AppData\Local\Temp\arduino_build_459886\sketch\ESPboyInit.cpp.cpp” -o nul
Alternatives for Wire.h: [Wire@1.0]
ResolveLibrary(Wire.h)
Utilisation de la bibliothèque ESP8266WiFi version 1.0 dans le dossier: C:\Users\Jean-Charles\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4\libraries\ESP8266WiFi
exit status 1
Erreur de compilation pour la carte LOLIN(WEMOS) D1 R2 & mini
“C:\Users\Jean-Charles\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\2.5.0-4-b40a506/bin/xtensa-lx106-elf-g++” -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ “-IC:\Users\Jean-Charles\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4/tools/sdk/include” “-IC:\Users\Jean-Charles\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4/tools/sdk/lwip2/include” “-IC:\Users\Jean-Charles\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4/tools/sdk/libc/xtensa-lx106-elf/include” “-IC:\Users\JEAN-C~1\AppData\Local\Temp\arduino_build_459886/core” -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++11 -MMD -ffunction-sections -fdata-sections -fno-exceptions -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10812 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 “-DARDUINO_BOARD=“ESP8266_WEMOS_D1MINI”” -DFLASHMODE_DIO -DESP8266 “-IC:\Users\Jean-Charles\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4\cores\esp8266” “-IC:\Users\Jean-Charles\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4\variants\d1_mini” “-IC:\Program Files (x86)\Arduino\libraries\Adafruit_MCP23017_Arduino_Library” “-IC:\Users\Jean-Charles\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4\libraries\Wire” “-IC:\Program Files (x86)\Arduino\libraries\Adafruit_MCP4725” “-IC:\Program Files (x86)\Arduino\libraries\TFT_eSPI” “-IC:\Users\Jean-Charles\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4\libraries\SPI” “-IC:\Users\Jean-Charles\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4\libraries\ESP8266WiFi\src” “C:\Users\JEAN-C~1\AppData\Local\Temp\arduino_build_459886\sketch\ESPboyInit.cpp.cpp” -o “C:\Users\JEAN-C~1\AppData\Local\Temp\arduino_build_459886\sketch\ESPboyInit.cpp.cpp.o”
“C:\Users\Jean-Charles\AppData\Local\Arduino15\packages\esp8266\tools\python3\3.7.2-post1/python3” “C:\Users\Jean-Charles\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4/tools/sizes.py” --elf “C:\Users\JEAN-C~1\AppData\Local\Temp\arduino_build_459886/ESPboyInit.cpp.elf” --path “C:\Users\Jean-Charles\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\2.5.0-4-b40a506/bin”
Executable segment sizes:
IROM : 253152 - code in flash (default or ICACHE_FLASH_ATTR)
IRAM : 28844 / 32768 - code in IRAM (ICACHE_RAM_ATTR, ISRs…)
DATA : 1264 ) - initialized variables (global, static) in RAM/HEAP
RODATA : 828 ) / 81920 - constants (global, static) in RAM/HEAP
BSS : 25928 ) - zeroed variables (global, static) in RAM/HEAP
Utilisation de la bibliothèque Adafruit_MCP23017_Arduino_Library version 1.0.6 dans le dossier: C:\Program Files (x86)\Arduino\libraries\Adafruit_MCP23017_Arduino_Library
Utilisation de la bibliothèque Wire version 1.0 dans le dossier: C:\Users\Jean-Charles\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4\libraries\Wire
C:\Users\Jean-Charles\AppData\Local\Arduino15\packages\esp8266\tools\python3\3.7.2-post1/python3 C:\Users\Jean-Charles\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4/tools/upload.py --chip esp8266 --port COM6 --baud 921600 --before default_reset --after hard_reset write_flash 0x0 C:\Users\JEAN-C~1\AppData\Local\Temp\arduino_build_459886/ESPboyInit.cpp.bin
esptool.py v2.8
Traceback (most recent call last):
Une erreur est survenue lors du transfert du croquis
Serial port COM6
File “C:\Users\Jean-Charles\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4/tools/upload.py”, line 65, in
esptool.main(cmdline)
File “C:/Users/Jean-Charles/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/2.7.4/tools/esptool\esptool.py”, line 2889, in main
esp = chip_class(each_port, initial_baud, args.trace)
File “C:/Users/Jean-Charles/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/2.7.4/tools/esptool\esptool.py”, line 237, in init
self.port = serial.serial_for_url(port)
File "C:/Users/Jean-Charles/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/2.7.4/tools/pyserial\serial_init.py", line 88, in serial_for_url
instance.open()
File “C:/Users/Jean-Charles/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/2.7.4/tools/pyserial\serial\serialwin32.py”, line 62, in open
raise SerialException(“could not open port {!r}: {!r}”.format(self.portstr, ctypes.WinError()))
serial.serialutil.SerialException: could not open port ‘COM6’: FileNotFoundError(2, ‘Le fichier sp�cifi� est introuvable.’, None, 2)
No Card name showed in front of USB Com
I will have to make some more tests and begin things now
